Difference between 92 rear disc's and 93-97 rear disc's?
Old Mar 14, 2007 | 01:10 PM
92Z's Avatar
92Z
I called to order a Strande 12 bolt today and they were telling me that there is a difference between the 92 rear disc's and the 93-97 rear disc's. I always thought that they were the same. My rears have the PBR calipers. I heard that GM started putting the PBR's on the 91 and 92's because they had run there supply out and the PBR's were going on the 4th Gen's so they started to use them. Any replies appreciated.
Old Mar 14, 2007 | 03:11 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
The calipers themselves are essentially the same. IIRC, the backing plates are a bit beefier. The rotors may be a bit thicker. A search will no doubt provide more specific info.
JamesC
Old Mar 14, 2007 | 11:53 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
The PBR calipers were used on F-bodies from 89-97. I am not sure if the parts are exactly the same, but they are compatible with each other.
hectre13
Dec 11, 2023 08:14 AM
Vintageracer
Jan 10, 2020 05:33 PM
colton_carlson
Mar 8, 2019 12:21 PM
sailtexas186548
Jan 19, 2016 12:21 PM
86White_T/A305
Aug 17, 2015 12:16 AM
