Help with brake problem
Old Mar 26, 2007 | 09:21 AM
GMZombie's Avatar
Car: 89 Camaro RS Convertible
Engine: 355 chevy power
Transmission: 5 speed manual
Axle/Gears: standard
ok i have this one problem when im braking the car seems to shake a bit..it seems to be because of the pass. side. and it only happens when i brake otherwise it seems fine? where should i start. there is Absolutely no pull when i brake so i now the caliper isnt sticking..could this be an alignment problem or a caliper problem or what? stumped here.
Old Mar 26, 2007 | 09:51 AM
bilms01's Avatar
Car: 89 Firebird
Engine: 350 Ramjet
Axle/Gears: GM 9 bolt 3:27
Re: Help with brake problem
Warped rotors, very loose front suspension parts will cause that. My money would be on the rotors.
ZMWojnar
Brakes
May 12, 2019 10:43 PM
SpaniardV6
Brakes
19
Sep 7, 2015 03:04 AM
overdriv
Aug 20, 2015 03:52 PM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
