Help! Stripped the passengar side hard line nut
Old Apr 22, 2007 | 10:50 AM
Oddball's Avatar
Car: '86 IROC-Z
Engine: LG4 305-4BBL
I was replacing the rubber lines with steel braided lines. Drivers side went perfectly. When I went to do the passengar's side, the nut was tight and I think I stripped some of it. I was using brake / fuel line wrenches. Even tried vice grips.
And ideas how I can loosen the connection between the hard line and the flex hose?
Old Apr 22, 2007 | 11:21 AM
thedude's Avatar
Car: 85 Trans Am
Engine: LG4
Re: Help! Stripped the passengar side hard line nut
Spray a decent amount of penetrant (WD-40, liquid wrench) on the fitting, let it soak for a while, then clamp on a set of vice grips as tight as you can possibly get them on. I had trouble with quite a few cars in this area due to rust and age/sitting untouched for years.
Old Apr 22, 2007 | 12:06 PM
Oddball's Avatar
Car: '86 IROC-Z
Did that. No luck. Should I use a large vice grip? I used the smallest the store had.
Old Apr 22, 2007 | 12:15 PM
thedude's Avatar
Car: 85 Trans Am
Engine: LG4
Yes, a larger pair will do a better job, more leverage and more grip. You may have to replace the fitting on the steel line, or part of the line itself, which can turn into a pain in the ***..but sometimes there's just some things you have to do...
Old Apr 22, 2007 | 01:07 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
mine were so bad i broke them all, on the whole car except the passenger side front, thank god, or id have to pull the motor to get the old line off.
Old Apr 22, 2007 | 06:36 PM
Oddball's Avatar
Car: '86 IROC-Z
Oy. Well hopefully with a larger vice grip I can loosen the fitting. If not I get to learn about putting on new ends.
Old Apr 22, 2007 | 08:08 PM
thedude's Avatar
Car: 85 Trans Am
Engine: LG4
You shouldn't have to pull the engine. If worse comes to worse, cut off as much of the line as you can, and route a new line somewhere else, as long as it gets the fluid pressure to where it needs to be.
MoJoe
Fabrication
Aug 19, 2017 07:12 PM
Leggman1
Brakes
Aug 12, 2015 08:39 PM
sonu1975
Aug 11, 2015 08:38 AM
MustangEater82
Brakes
Aug 11, 2015 07:52 AM
Elliswon
Aug 10, 2015 12:33 PM
