Installed new Calipers, now they won't bleed!!
Old May 12, 2007 | 05:14 PM
Dante93GTZ's Avatar
Car: 1992 Z28 Heritage Edition
Axle/Gears: 3.23:1
I just installed new rotors, pads, and calipers and now I have a problem. The pass side caliper won't bleed. I have confirmed fluid to the rubber hose, but I can't get anything through the caliper. To prove that there is no fluid, I spun the tire manually and had my wife hold the brake pedal to the floor, and NOTHING, no stoppage at all.
Any ideas? A bad caliper maybe??
Old May 12, 2007 | 05:47 PM
NoItsNotForSale's Avatar
Car: 87 & 89 Iroc's
Engine: 5.0 - 5.7
Transmission: 700R's
Axle/Gears: 2.77 - 3.70
Re: Installed new Calipers, now they won't bleed!!
To the hose or from the hose? If you are getting fluid at the caliper end of the hose the caliper must be faulty.
Old May 12, 2007 | 07:05 PM
Dante93GTZ's Avatar
Axle/Gears: 3.23:1
Checked again... took the hose off at the caliper and lots of fluid is present.
Just got back from swapping out the caliper for a new one and same result!!
Any ideas? Could my hose be binding when I secure it to the caliper?
Old May 12, 2007 | 07:31 PM
blyth18md's Avatar
Car: 82z28
Engine: 406
Transmission: th350
bleeder screw located at the top of the caliper?
Old May 12, 2007 | 08:41 PM
Dante93GTZ's Avatar
Axle/Gears: 3.23:1
I thought the hose was binding up so I bought a new one and that seems to have fixed the fluid leak part of it.
I was able to begin bleeding the brakes, however it has been probably 6 total cycles (pump, pump, pump, hold -- bleed) and there is still air being vented out.
Is that normal?? Could it be that the pedal isn't being pushed in far enough?
Old May 14, 2007 | 04:17 PM
fire350tpi's Avatar
Car: 1988 Pontiac trans am/gta
Axle/Gears: 3.23's
Try 5 hard pumps and hold, and do it until no air comes out, and make sure your master cylinder level is up and not letting more air in the system
Old May 14, 2007 | 07:53 PM
2kflhr's Avatar
Car: '68 396 SS/RS, '02 SS
Sometimes it works better to have foot completely off of the pedal open the bleeder valve, depress pedal slowly but consistently until on the floor, close valve and repeat several times before using the pumping method. Sometimes the pumping action stirs the air up and makes it difficult to bleed.
1992rs/ss
Jan 31, 2025 05:10 PM
25thannivZ28
Aftermarket Product Review
Jan 2, 2016 05:41 PM
backtothe80s
Sep 5, 2015 12:39 AM
red90IROCls1
Aug 25, 2015 06:56 AM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
