82 Camaro, rear drum, proportional valve
Old May 21, 2007 | 09:20 PM
yzarcem's Avatar
Car: 82 Camaro; in process of resto
Engine: 350 4bbl.
Transmission: 700R4 with B&M Lockup
Axle/Gears: Moser 28-spline axle; 3.23 gears
I'm at an impass. I just dumped my car fund $$ into the rear-end (rear axle was leaking...so I upgraded to 28 spline with posi & new gears), a new slave cylinder in the rear, new rear brakes (drum) and replacement lines on the front. Having never messed the the rear end before, and being strapped tor time, I had someone else do the work.
Now it's time to bleed the brakes. It appears the propotioning or proportional valve is 'stuck.' I lost too much brake fluid (that's why I took it in the beginning...little to no brakes), and evidentally they can't reset the valve. They pulled one from an 85...but no joy. It was a different type. They pulled one from an 83...no joy. Can't find one from an 82. My mechanic says it is iron? Does anyone know what I have here? It seems unique to the '82 for some reason.
Summit has adjustable ones, but my car is a daily driver...and street-bound.
What are my options here...how can I work my way out of this? I can't afford to change the rear brakes to disc right now after all the other work. I'm too far in. Is there a re-build kit, or someone that has re-makes? I've been looking for a week. Thanks for any direction, guys.
Old May 21, 2007 | 11:27 PM
82CrossFire Z28's Avatar
Car: 82 Camaro Z28, 88 IROC-Z
Engine: 5.0L TBI., 5.7TPI
Transmission: Auto TH200C, 700R4
Axle/Gears: 3.23 posi, ones that rotate!
Re: 82 Camaro, rear drum, proportional valve
I think gmpartsdirect.com has the brake valve you are looking for. It is part number 18009374 and is hidded under the cryptic name of "Repair K". If you go to their home page you can enter in the part number and it will give you the price. $32.xx plus shipping, taxes, profit, etc. To see a diagram of it, on the home page select the tab for Catlog, agree to the terms, enter the model info and click on search. On the results page, select the MECHANICAL tab, then click on BRAKES, then click on the double inverted arrow on the line for REPAIR K, then the link to 12 for the rear durm brakes. If that is the part you need, there you go. Otherwise you might look around a bit.
Dave
Old Jun 6, 2007 | 10:53 AM
yzarcem's Avatar
Engine: 350 4bbl.
Thanks for the tip...no joy, though. That part is the Master Cylinder rebuild kit. At first glance, the prop valve appears available through GM, but when I we try to locate it, it is not in stock, and no longer available. I've tried all of the restoration places I could think of, but 82 is too new for them...and too old for GM. I'll update and let you know what I wind up doing, so others in the same boat may benefit.
Old Jun 11, 2007 | 09:03 PM
yzarcem's Avatar
Engine: 350 4bbl.
The car has been down for a month now, and I'm at a total loss. No prop valve...no brakes. What would you do if this were your car...and a frequent driver at that? I just can't afford a rear brake conversion right now, but it has to be street-safe. Help??
Old Jun 12, 2007 | 05:35 PM
compuwiz1937's Avatar
Car: 2012 Corvette
Engine: LS3
Transmission: TR6060
Junk yard?
Old Oct 11, 2007 | 05:28 AM
blackbeauty's Avatar
Car: 1989 Trans Am
Engine: 1989 305 TPI
Transmission: 700-R4
Axle/Gears: 2.77 10 bolt
yzarcem, did you ever get this sorted?
jaridjohn
Jul 8, 2024 03:49 PM
Scorched1984
Wheels and Tires
66
Apr 16, 2016 06:56 PM
AkDrifted
Aug 17, 2015 07:45 PM
Leggman1
Brakes
Aug 12, 2015 08:39 PM
THABADGUY
Brakes
Aug 11, 2015 03:43 AM
