What am I supposed to do for a prop valve now?
Old Jun 7, 2007 | 09:50 AM
compuwiz1937's Avatar
Car: 2012 Corvette
Engine: LS3
Transmission: TR6060
So right now I have rear cast iron disk brakes from an 84 Camaro and the stock cast iron brakes that came on my 91. I have the factory disk/drum prop/combo valve and I'm fixing to order C5 front brakes and when I eventually get to do an LS1 swap I'm going to swap in the 4th gen disk rear. I want to get the right valve so the rear brakes I have now work properly and when I get the rear LS1s that they work properly too. Right now I don't think my rear brakes are doing much because when I put on the e-brake it doesn't do much. If I remeber right I was told to get a 1LE valve, but Chevy doens't make them any more. So what am I supposed to do now? There are some GM disk/disk combo valves on eBay but I don't know if it'll work on my car.
Old Jun 7, 2007 | 04:56 PM
krisb410's Avatar
Car: 91 RS Camaro, 75 L82 Corvette
Engine: LO3, 383 Stroker
Transmission: 700R4, TH400
Axle/Gears: 4th gen 3.23 posi/LS1 discs, stock
Re: What am I supposed to do for a prop valve now?
I just picked up a 91-92 1LE valve at the dealer a few weeks ago.
Old Jun 7, 2007 | 08:06 PM
Car: 2012 Corvette
Engine: LS3
Hmm. What part number did you give them? How much was it?
Old Jun 7, 2007 | 08:16 PM
krisb410's Avatar
I just walked into the parts dept and asked for a 91 or 92 ( I forget which year I asked for, but it was either 91 or 92) prop valve for a 1LE car. I have the part # at home, somewhere. It was only like 68 bux.
Old Jun 7, 2007 | 08:42 PM
Car: 2012 Corvette
Engine: LS3
That's not bad. I guess I'll call the dealership again and ask for the specific part instead of just giving them the part number.
Old Jun 9, 2007 | 12:02 PM
krisb410's Avatar
Just found the invoice, it was part # 10164112. It lists for $118.40 and I got it for $64.67.
Old Jun 9, 2007 | 01:13 PM
crrllmich's Avatar
Car: 91 Camaro RS, 99 Camaro Z28
Engine: L03, LS1
Transmission: 700R4, T56
Axle/Gears: bunch of 10 bolts how scary is that
www.gmpartsdirect.com
GM Part # 10164112 as Kris said.
Without connections thats problem your cheapest bet.
Old Jun 9, 2007 | 01:35 PM
Car: 2012 Corvette
Engine: LS3
I must have had an old part number then. I'll have to call the dealers on Monday since the parts departments are closed now.
Does anyone know if the 1LE prop valve will cause a problem with my cast iron rear disks? It'll probably be a while before I get PBR/LS1 brakes back there because I can't afford to do the LS1 swap yet. I have to have working rear brakes or I don't think I'll pass the emissions dyno test.
Old Jun 11, 2007 | 11:05 AM
Car: 2012 Corvette
Engine: LS3
Damn all the dealers here want the $118.40. Sam Taylor Buick/Cadillac in Florida has it for $65 + shipping though. I'm a little weary of gmpartsdirect.com. I've heard they take forever to ship. Sam Taylor has a good reputation so I suppose I'll order it from them before this thing goes extinct.
Hotrodboba400
Dec 10, 2019 07:07 PM
db057
Apr 28, 2019 07:45 AM
Nick McCardle
Sep 10, 2015 08:36 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
