Hard Brakes Cant bleed them.
Old Jun 8, 2007 | 09:29 AM
jcp74's Avatar
Hello. I have an 89 GTA, Its been sitting for 6 or 7 years, I just replaced front rotors, calipers and pads, First I tried to change the fluid but it wouldent bleed. The pedal is really hard and does move slowly,I got fluid from the drivers side but nothing frome the passengers side except what was in the caliper, I took the hoses off the calipers to gravity bleed but nothing.
I diddent have time to take the hoses completly off to see if the hoses were bad. The car was sitting on pavement and the metal lines looked good when we had it on the lift. I havent touched the back breakes at all yet. I think I have ither bad hoses or, a stuck master cylender <---mis spelled! LOL. Any advice would be helpful. Thanks guys!!
Old Jun 8, 2007 | 11:53 AM
bilms01's Avatar
Car: 89 Firebird
Engine: 350 Ramjet
Axle/Gears: GM 9 bolt 3:27
Re: Hard Brakes Cant bleed them.
Replace the hoses. probably collapsed inside. After sitting that long I would suggest replacing all 3 hoses and the rear hydraulics and strongly consider the Master Cylinder. No telling what condition the seals could be in
Old Jun 8, 2007 | 12:26 PM
UNCLE TOM's Avatar
Car: 91 R/S , 89 dodge p/u
Engine: L31 GM crate re-cammed , 318
Transmission: T-5 , 4 speed auto
Axle/Gears: 3.42 , ?
happened to me and car had not set that long .
Old Jun 8, 2007 | 12:56 PM
jcp74's Avatar
Thanks for the advice guys! I'm gonna go down monday and get rid of the hoses. I have rear calipers comming and master cylinders arn't that expensive. Thanks a million, Ill update when done
Terrell351
Jun 13, 2021 01:13 PM
backtothe80s
Sep 5, 2015 12:39 AM
MustangEater82
Brakes
Aug 11, 2015 07:52 AM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
