best brake pads
Old Jun 19, 2007 | 08:25 AM
jaysfs's Avatar
Car: 91 z28, 07 trailblazer ss
Engine: lt1lt4 hot cam,ls2
Transmission: t56
best brake pads
I do`t know what i have on my vert but my wheels never get brake dust on them. Now my z is a totally different story, acouple days after i clean that thing the wheels are dirty. So what do you guys think is the best brake pads too buy for my z?
Old Jun 19, 2007 | 09:29 AM
xplane's Avatar
Car: 85 camaro sport coupe
Engine: 2.8 MFI
Transmission: v6 700R4 wish it was a 5spd Stick
Axle/Gears: Stock non posi 3.42s
Re: best brake pads
you may have performance pads or cheepies on the Z as the normaly make more dust. also you probably drive the Z harder so that will cause more brake dust.
Pull the Verts pads and look at the part numbers.
Old Jun 19, 2007 | 10:49 AM
Randy82WS7's Avatar
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
Re: best brake pads
the sofest(organic) pads are the messiest and wear down the rotors the least but arent very heat resistant
the semi metallics are heat resistant and not very messy at all but wear down the rotors alot faster
the ceramics i have no idea but are suposed to be the highest resistance to heat and i dont know how much they wear rotors down
you have to figure out what you want
longer lasting rotors, or cleaner wheels
or if you have a brake fade issue then you will have no choice but to get semi metallic or better
usually organic came from factory except in some packages
and usually the metallics came from factory on service duty vehicles such as 9C1 and 9C6 packages and so on
good luck
Old Jun 19, 2007 | 03:08 PM
jaysfs's Avatar
Transmission: t56
Re: best brake pads
i almost always baby the z so yes i might have too just check what is on my vert
BADNBLK
Convertibles
Sep 21, 2015 07:56 PM
dbrochard
Sep 19, 2015 08:13 PM
lock1983
Brakes
Sep 9, 2015 09:08 PM
Buickstaged
Brakes
Sep 4, 2015 07:53 AM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:50 PM
