Brake Problems and I suck at searching. HELP PLZ!!
Old Jun 19, 2007 | 01:09 AM
streetheatz28's Avatar
Car: 88 Sportcoupe camaro
Engine: forged 355
Transmission: th350
I've tried to search but I couldent come up with anything. I have a 86 z28 with 4 wheels disc brakes. I put new break pads all the way around and bled the brakes but I still don't have much stopping power. I have to add brake fluid about every 2 weeks or less. Anyone know what the problem could be? Thanks in advance!
Old Jun 19, 2007 | 09:36 AM
82 Indy Z's Avatar
Car: 1982 Indy 500 Pace Car Replica
Engine: Stroked 350 (385ci) TPIS Mini-Ram
Transmission: 6-speed
Axle/Gears: Stock w/Disks and 4.10's
Re: Brake Problems and I suck at searching. HELP PLZ!!
First, if you are having to add fluid every 2 weeks, you have a problem. Brakes are a closed system, meaning nothing is lost unless you develop a leak. Second, bu stopping power do you mean they tires won't lock up? I have an 82 Z-28 with 4 wheel disk and they have never locked up on a good road. The car stops fine but the wheels do not lock up without a lot of effort. Installing braided hoses would help too. Truth is stock brakes are small for the 16" wheels and with my 15" they would lock up a bit easier. I am currently in the process of an LS1 conversion.
Your main concern is to find your leak and go from there. Hope this helps
Old Jun 19, 2007 | 03:50 PM
Vortex91's Avatar
Car: Camaro RS '91
Engine: 305 TBI
Transmission: Auto w/ TransGo shift kit
I agree with Indy, you have a leak. Fix that first an then see if the wheels lock up.
ZMWojnar
Brakes
May 12, 2019 10:43 PM
SpaniardV6
Brakes
19
Sep 7, 2015 03:04 AM
Leggman1
Brakes
Aug 12, 2015 08:39 PM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
