Brake line to caliper hose: What size is the adapter?
Old Jun 18, 2007 | 03:41 PM
Vortex91's Avatar
Car: Camaro RS '91
Engine: 305 TBI
Transmission: Auto w/ TransGo shift kit
What size is the adapter that goes between the line coming from the master cylinder and the rubber hose that goes to the caliper and is mounted to the frame with a C clip?
My plan is to install a CPP master cylinder that has 3/8 fittings using Summit's stainless steel lines (1/4 and 3/16) with the appropriate fittings and adapters but I'd like to stay as close as possible to stock sizes.
Does anyone have the exact sizes for brake lines, fittings and adapters for our cars?
I understand the front lines are 1/4 and the lines from the T on the rear axle are 3/16. Is this correct?
D.
Old Jun 19, 2007 | 06:40 PM
Vortex91's Avatar
Car: Camaro RS '91
Engine: 305 TBI
Re: Brake line to caliper hose: What size is the adapter?
Assuming I get 3/8 fittings can I use a 3/8 male to male adapter and if so where can I buy one? I searched Summit's site for these adapters but nothing came up. Do you know of any online vendors I can use?
D.
Reddeath210
Oct 6, 2015 08:20 AM
Nj1987
Aug 19, 2015 08:26 PM
Leggman1
Brakes
Aug 12, 2015 08:39 PM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
Leggman1
Aug 6, 2015 04:15 AM
