Caliper won't bleed
Old Jun 25, 2007 | 12:44 AM
zapr's Avatar
Car: 1985 camaro z28
Engine: 305 lg4
Caliper won't bleed
.........I just finished installing new calipers and rear brake cylinders and bled the system starting with the master cylinder. Problem is, the passenger caliper won't bleed. No fluid will bleed through the bleeder valve. A buddy said the flex hose is collapsed. Any ideas? Thanks.........Zapr.
Old Jun 28, 2007 | 01:23 AM
scottsz28's Avatar
Re: Caliper won't bleed
yup sounds like your friend is correct, could be something else, maybe a problem with the line some where, just trace the line from the master to the hose is everything looks good there pick yourself of up braided line, or just a replacment hose
Old Jul 2, 2007 | 08:18 PM
zapr's Avatar
Engine: 305 lg4
.......Yep. You're right. That's what it was. Got the new flex hose put on and guess what? The other side wouldn't bleed anymore. Had to replace the driver side flex hose as well. Should have known better and just got both hoses at the same time. Everything is good now. Thanks for your help.....Zapr.
Bubbajones_ya
Oct 25, 2015 08:01 PM
Spyder_TheGamer
Oct 2, 2015 12:25 PM
Agent507943
Firebirds Wanted
Oct 2, 2015 07:18 AM
Luigytico09
Oct 1, 2015 08:46 AM
the_hamturdler
Sep 30, 2015 12:50 PM
