Got my front c5/z06 brakes on today!
Old Aug 17, 2007 | 08:54 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
I finally got all the parts together and installed my c5 front brakes today. They came out very well and look killer behind the wheels, dont know how they work yet, car is not finished, but a vast improvement over my old crappy single piston iron calipers. Wheels are 18" centerline daggers
Old Aug 17, 2007 | 09:16 PM
kuulkatdadieo's Avatar
Car: 1989 Pontiac GTA
Engine: 350 5.7 T.P.I.
Transmission: TH 700-R4
Re: Got my front c5/z06 brakes on today!
Did you put those brakes together, or did you order them as a kit??
Old Aug 17, 2007 | 09:47 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
i bought the spindles/hubs/brackets assembled, from another member here at TGO, the rotors are factory z06 rotors from ebay and the calipers are 2004 zo6 calipers also from ebay.
Old Aug 20, 2007 | 12:22 PM
krisb410's Avatar
Car: 91 RS Camaro, 75 L82 Corvette
Engine: LO3, 383 Stroker
Transmission: 700R4, TH400
Axle/Gears: 4th gen 3.23 posi/LS1 discs, stock
Looking good Phil, I hope to get similar setup on my car.
Old Aug 20, 2007 | 08:27 PM
Old Aug 21, 2007 | 10:52 PM
ebmiller88's Avatar
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
Nice!
Ed
Old Aug 22, 2007 | 05:11 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Originally Posted by ebmiller88
Nice!
Hey, Ed, I see these C upgrades and I recall not too long ago that Dan Burke, AndyZ28 and others (I remember your asking a ton of questions) succeeded in the 1LE upgrade. At that time, the 1LE and Baer brakes were about the best that a thirdgen car could achieve. Times have changed! Still, I'm satisfied with my 1LE front/rear combo. Keep up the R&D.
JamesC
Old Aug 22, 2007 | 08:58 AM
dennisbernal91z's Avatar
Car: Building LS3, T56 Z28
Engine: LS3
Axle/Gears: Moser/ 4.11
nice brakes, i am doing the same swap from parts pieced together. i got all my stuff - spindles/hubs/and brakets from Neil. and I am getting the hubs/brakets from Ebmiller, and finally modding the spindles myself.
Total cost is going to be around $720 for full C5/Z06 front brakes with sloted, drilled and zinc washed rotors.
How much were those ebay rotors? are they washed?
Old Aug 22, 2007 | 07:30 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
i think they were a whole $125 for both, they are stock replacements, delco i think, so i do not believe the are zinc washed, but im not sure. I think the whole setup was less $700
Old Aug 23, 2007 | 07:07 AM
Engine: LS3
Nice.
Old Sep 4, 2007 | 08:35 AM
Engine: LS3
I got mine on over the weekend. And DAMN. They are great. i think I did something wrong though. The bleeders are supposed to be on the top right? I installed them the other way around and the bleeders are on the bottom... When I bled the lines I had to take the caliper off the hub and hold it upside down. I had beek working for 5 hours so I wasn't gonna witch them around just yet. I drove the car and it works great, but I just wanna know if today after woork I should go back and swap the calipers around?
Old Sep 4, 2007 | 06:44 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
yup, the bleeder goes on the top.
Frozer!!!
Jan 19, 2024 04:55 PM
Scorched1984
Wheels and Tires
66
Apr 16, 2016 06:56 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
SpaniardV6
Brakes
19
Sep 7, 2015 03:04 AM
Leggman1
Brakes
Aug 12, 2015 08:39 PM
