S-10 manual master cylinder HELP!!!!!
Old Aug 20, 2007 | 09:26 PM
FASTIROC's Avatar
Hello everyone. I recenetly decided to put a s-10 master cylinder on my car. I made the mounting bracket and the push rod is cut to length as is the pedal drilled 1 inch higher. My question is on the brake lines. Does anyone know the adapters needed to finish this. I know you need to go from bubble flare to inverted flare but i cant seem to find any info on this. I have searched all over so any info would be greatly appreciated. Part numbers or just sizes would be great.
Matt
Old Aug 22, 2007 | 03:18 PM
FASTIROC's Avatar
Re: S-10 manual master cylinder HELP!!!!!
Nobody knows the size adapters I need for this. I know a bunch of you have done the swap and I have read your post but nobody has posted any sizes and I cant seem to find a shop that can help me determine the sizes.
Matt
manualbrakes.com
Brakes
63
Apr 9, 2024 11:55 AM
88SS6SPEED
Nov 11, 2015 07:05 AM
codeysabatini
Nov 10, 2015 04:07 PM
camaro1185
Oct 26, 2015 06:51 AM
