Difference?
Car: '91 Z28, '13 Civic EX-L
Engine: 355 LT1, 1.8 I4
Transmission: T56, 5spd auto
Axle/Gears: 10 bolt 3.42(as long as no breaky)
Difference?
There may already be answers to this but i couldnt find any so...
Are the Banjo bolts between the stock single piston caliper and the LS1 caliper different?
I tried to tighten the stock bolt onto a LS1 caliper and it pulled the threads right out.
Hopefully if the bolts are a different size there is enough thread left in the caliper to work.
Thanks guys for any info.
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: Difference?
i found that with the c5 calipers, which are pretty much the same, the banjo threads are a finer thread than the stock threads
Re: Difference?
Yeah i went to the yard today and picked up 2 bolts for 5 bucks
The bolts are also longer which is good. The other bolt wasnt able to strip all the threads out. haha lucky me.
Numbah-1
Sep 12, 2015 08:57 PM
