Pic of 1LE on 9 Bolt
Car: 1986 Pontiac TA
Engine: 383
Axle/Gears: 3.70
I'm looking for a pic or pics of a 1LE upgrade on a 9 bolt rear. I've looked at the post from JamesC but the spring perches are different than mine and I want to see the brake line routing.
Thanks!
Thanks!
Car: 87 GTA
Re: Pic of 1LE on 9 Bolt
Before 89, 9 bolts had iron calipers. Starting in 89, the 9 bolts got the PBR calipers.
I'm not sure what JamesC has, that you are referring to, but there would be differences, between the years.
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
It's not the best picture - but you can make out the brake lines......
Car: 87 GTA
The rear 1LEs, weren't PBRs, like the 89 & later 9 bolts stock? Or rather, the '89 & later 9-bolts, weren't the same as 1LEs? I've never looked.
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
https://www.thirdgen.org/forums/atta...-what-diff.jpg
JamesC
