Drum rear to C5/C6 conversion plates done
Old Dec 19, 2008 | 04:21 AM
  #51
VAN454's Avatar
Car: 88 GTA
Engine: Ls1
Axle/Gears: 9 bolt 3.27
Re: Drum rear to C5/C6 conversion plates done
This is a very cool setup, how long until you get the bugs ironed out? Will you be doing a 9 bolt disc brake version?
Old Dec 19, 2008 | 09:03 AM
  #52
scooter's Avatar
Car: 92 Firebird
Engine: 4.8 LR4
Axle/Gears: 3.45 9 Bolt
Did the 9 bolt ever get a drum rear? I didnt think so, if not then you would never need this on a 9 bolt
Old Dec 19, 2008 | 01:30 PM
  #53
VAN454's Avatar
Car: 88 GTA
Engine: Ls1
I'm not sure if they were available with drums, but the discs aren't very good, 10.5 in and a crap iron caliper.
Old Dec 19, 2008 | 03:54 PM
  #54
ebmiller88's Avatar
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
Hopefully not too long, I'll get the spacers cut when I get back and see how the other setup works out. Some 9 bolts did get drums although they're not too common but this concept should work on both drum and disc rears as I have it now. We'll see in a couple weeks. Thanks for the patience.
Ed
Old Jan 29, 2009 | 01:36 AM
  #55
SLoV's Avatar
looks dam nice
ebmiller88 im going to shoot you a pm reg info on this, as im about to under go brake upgrades.
i know im a new member but please be nice
Old Feb 12, 2009 | 12:03 PM
  #56
Tice's Avatar
Car: 1991 Formula Firebird
Engine: Pontiac 355 stroker (305 TBI 4Sale)
Transmission: Pending Manual , 700r4 for sale...
Axle/Gears: Stock... for now
Updates?
Old Mar 10, 2009 | 11:23 PM
  #57
FASTERTHANUMARK's Avatar
Car: 1970 Nova
Engine: 850HP 383
Transmission: TH400 w/ Brake
Axle/Gears: 4.88 12 Bolt
Any info on the Vette ebrake setup,brackets,e brake cables?
Old Mar 24, 2009 | 07:01 PM
  #58
Car: 1970 Nova
Engine: 850HP 383
Anything by chance?
Old Mar 27, 2009 | 03:19 PM
  #59
nomind's Avatar
Car: 85 Trans Am
Engine: LB9
Transmission: Finally Fixed (T5)
Yes, any updates, please. My '85 is almost road ready, and I'm very interested.
The 9 bolt was available with a drum setup. I know this for fact, as I've got one.
Old Apr 1, 2009 | 10:45 PM
  #60
1987CamaroZ28's Avatar
Car: 1987 IrocZ
Engine: lb9
Transmission: 5 spd
Axle/Gears: factory 9 bolt with 3.45 gears
Ed need your help.
I have an 87 9 bolt with the iron calipers. I would like to upgrade to either the stock aluminum calipers (89 and up) or go with the c5 calipers. What would i need to do to get the stock aluminum calipers to work? what would i need to do to get the c5 calipers to work? advantages or each? Thanks! Here's a couple pics of my backing plates, so you can see what is currently equipped.
Attached Thumbnails Drum rear to C5/C6 conversion plates done-left-rear.jpg
Old Apr 1, 2009 | 11:13 PM
  #61
Car: 1987 IrocZ
Engine: lb9
Transmission: 5 spd
Here are a couple more
Attached Thumbnails Drum rear to C5/C6 conversion plates done-left-backing-plate.jpg
Old Apr 1, 2009 | 11:17 PM
  #62
Car: 1987 IrocZ
Engine: lb9
Transmission: 5 spd
ff
Attached Thumbnails Drum rear to C5/C6 conversion plates done-left-backing-plate-2.jpg
Old Apr 1, 2009 | 11:18 PM
  #63
Car: 1987 IrocZ
Engine: lb9
Transmission: 5 spd
what the heck do i have ed?
Old Apr 2, 2009 | 04:31 PM
  #64
Twin_Turbo's Avatar
You have the same rear end as i have (iron calipers) where the dr. side is trailing and the pass side is leading. You will need new backing plates to mount the calipers, as they are trailing. You'll also need new parking brake cables and new hard lines (or fab some yourself).
Old Apr 3, 2009 | 11:04 AM
  #65
Car: 1987 IrocZ
Engine: lb9
Transmission: 5 spd
This is helpful, thansk man.
Old Apr 5, 2009 | 09:08 PM
  #66
FueledSoul's Avatar
Car: 84 camaro, 88 trans am, 98 camaro
Engine: Modded , stock, LSX modded
Transmission: 700r4, 700r4, t-56
Axle/Gears: 327, 308, 373
Old Apr 5, 2009 | 09:25 PM
  #67
FueledSoul's Avatar
Iv had a few 9 bolts i would think it would be fairly easy to make some type of bracket. when i was painting one with discs i also pulled a 4thgen rear out of my friends car to replace it with something better from what i can remember the 10 bolt 4thgen rear i pulled with discs has the same axle housing flange as the 9 bolt like this Name:  bolts.jpg
Size:  58.6 KB i was going to take them both apart to see if they would bolt up but never got around to it. anyone know if there the same flange design?
Old Apr 5, 2009 | 09:28 PM
  #68
FueledSoul's Avatar
Old Apr 11, 2009 | 10:57 PM
  #69
FueledSoul's Avatar
anyone on the above?
Old May 4, 2009 | 09:06 PM
  #70
Car: 1970 Nova
Engine: 850HP 383
Anything on using ebrake w this yet Ed?
Old May 4, 2009 | 09:47 PM
  #71
shadowknight's Avatar
Car: 89 rs
Engine: 305 tbi
Axle/Gears: stock
super interested. i hate the F'n drums
Old May 27, 2010 | 10:50 AM
  #72
quickkris2006's Avatar
Car: 1991 camaro vert
Engine: ls1 soon
Transmission: t56 soon
Axle/Gears: moser 12bolt 4.10 soon!
how much for these brackets shipped to 08514 please pm
Old May 27, 2010 | 06:46 PM
  #73
VAN454's Avatar
Car: 88 GTA
Engine: Ls1
Originally Posted by FueledSoul
Iv had a few 9 bolts i would think it would be fairly easy to make some type of bracket. when i was painting one with discs i also pulled a 4thgen rear out of my friends car to replace it with something better from what i can remember the 10 bolt 4thgen rear i pulled with discs has the same axle housing flange as the 9 bolt like this i was going to take them both apart to see if they would bolt up but never got around to it. anyone know if there the same flange design?
Did you ever check this out? Do they bolt up?
Old May 27, 2010 | 06:52 PM
  #74
scooter's Avatar
Car: 92 Firebird
Engine: 4.8 LR4
All 10 bolts have the same flange for disc brakes. The 9 bolt is the one with the different flange but if you swap the 10 bolt ones laft to right you can re-drill them for the 9 bolt pattern so none of the holes overlap. I did it with the BAER 10 bolt backing plate for the PBR setup, I put them on my 9 bolt because BAER wanted a lot of money for the backing plates
Old May 27, 2010 | 09:21 PM
  #75
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
As scooter mentions, the bolt pattern on the backing plate is different between a 9- and 10-bolt. Ed's catalog lists several 9-bolt plates, to include those that accept 12 and 13" rotors.
JamesC
Old Sep 27, 2010 | 12:06 AM
  #76
85Z28NOS's Avatar
Car: 85 Camaro
Engine: 454 RamJet
Transmission: LT1/T56
Axle/Gears: 8.8w/4.10
I was wondering if you ever finished the drum to C5 disc plates with the parking brake set-up like you have pictured here? I looked on your web site and didnt find anuthing other than the ones you have posted at the beginning of this post. I am very interested in the ones posted here towards the end. Your parts look top notch! Keep up the GREAT work, Thanks
Old Aug 15, 2011 | 09:32 PM
  #77
chevy700's Avatar
I know this is an old thread but i was wondering if you have this plate kit for the disc rear ends. pleas let me know, Im really interested in getting my hands on these if not ill have to make them. im going to use the C6 Z06 brakes with the parking brake or maybe i could use a hydraulic parking brake and not have to us the factory parking brake. Let me know what you think. THANKS
Old Aug 15, 2011 | 09:46 PM
  #78
chevy700's Avatar
How much for these plates i think i can adapt them to work with the disc rearend
Old May 10, 2015 | 01:00 AM
  #79
Blake's Avatar
Car: 1991 Camaro RS
Engine: 406ci
Transmission: T-56 LT1
Following
Old Mar 23, 2020 | 03:22 PM
  #80
88Camano Street's Avatar
Originally Posted by Blake
Following
where i can get me an set of them setup at ???? Hit me up with prices. 88 Camaro BW 9bolt setup.
1992 Trans Am
May 10, 2023 07:19 PM
MoJoe
Fabrication
Aug 19, 2017 07:12 PM
SpaniardV6
Brakes
19
Sep 7, 2015 03:04 AM
Warlocksirix
Sep 3, 2015 12:26 PM
3rdgenparts
Aug 6, 2015 09:03 AM
