do lt1 or ls1 rear brakes bolt onto an 82 with discs
Car: 1985 Trans Am
Engine: vee eight
Transmission: auto
Axle/Gears: 4.10 gears
do the lt1 or ls1 rear brakes bolt right onto an 82 rear end with discs. I have a facotry 82 rear from a mecham trans am and it has discs. Someone wants to buy it and use lt1 or ls1 brakes. Do they bolt right onto the axle flange .
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: do lt1 or ls1 rear brakes bolt onto an 82 with discs
Last edited by //<86TA>\\; Oct 1, 2007 at 08:08 PM. Reason: oops, read what i wanted to see and not what was posted
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
With the correct backing plates, the LT1, which is essentially the 1LE set-up, will bolt to the axel flange.
https://www.thirdgen.org/forums/faq-...iscs-89-a.html
JamesC
JamesC
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
That'll be a 10 bolt so they both should bolt on easily with the right parts.
Ed
Ed
Car: 1985 Trans Am
Engine: vee eight
Transmission: auto
ed what parts do i need, to get the 4th gen stuff onto the 3rd gen rear end. ???
hectre13
Dec 11, 2023 08:14 AM
sailtexas186548
Jan 19, 2016 12:21 PM
