Will a 4th gen Master Cylinder fit in my 89?
Old Oct 11, 2007 | 12:53 AM
The Project's Avatar
Car: 89 IROC
Engine: 305 TPI / ZZ4 cam
Transmission: Stage 2 700R4, LS1 driveshaft
Axle/Gears: Strange 3.42 w/ Auburn
I was looking at swapping the master cylinder in my 89. It currently has rear drums but I will be switching to rear disc (someday soon).
Just wondering if a 4th gen Master Cylinder will fit in my 89?
Old Oct 14, 2007 | 04:19 AM
Car: 89 IROC
Re: Will a 4th gen Master Cylinder fit in my 89?
Anyone?
Old Oct 16, 2007 | 07:45 AM
MurcoRS's Avatar
Car: 1989 Camaro RS
Engine: ZZ4 350
Axle/Gears: BW 9-bolt w/3.73
Yes, it bolts on but you will need to bend some new lines to go to the prop valve and may need new fittings...
Old Oct 16, 2007 | 07:59 AM
Firebat's Avatar
Do you have to use a 4th gen brake booster? Do you have to modify any areas for it all to fit, like the firewall or wheelwell?
Old Oct 16, 2007 | 11:18 AM
scooter's Avatar
Car: 92 Firebird
Engine: 4.8 LR4
Axle/Gears: 3.45 9 Bolt
No it bolts directly to the 3rd gen booster, only mod necessary is to have new lines re-bent.
Old Oct 16, 2007 | 12:26 PM
MurcoRS's Avatar
Car: 1989 Camaro RS
Engine: ZZ4 350
It has the same mounting flange, bore size, and stroke if I'm remembering correctly. The major difference is the reservoir which stays cleaner, has slightly more capacity, seals better to keep moisture out, and is easier to bleed with a pressure bleeder.
Old Oct 16, 2007 | 06:13 PM
Firebat's Avatar
Would one from a 99 V6 be the same as one from the LS1 4th gens?
Old Oct 16, 2007 | 07:04 PM
MurcoRS's Avatar
Car: 1989 Camaro RS
Engine: ZZ4 350
Yes, all 1998 and later f-bodys used them..
Old Oct 17, 2007 | 12:05 PM
Car: 89 IROC
Perfect ....thanks.
Old Oct 20, 2007 | 10:05 PM
BOTTLEDZ28's Avatar
Transmission: A4
I think I remember someone onhere doing this and they sent out there assembly to a comany to have new lines custom bent for them. I have the 4th gen parts sitting on the shelf waiting to go inbut I just need the lines done and havent got to that part of my project yet. Maybe if I find the company that can make lines then i will open the hood
Old Oct 20, 2007 | 10:40 PM
scooter's Avatar
Car: 92 Firebird
Engine: 4.8 LR4
Finelinesinc.com will do them. I plan on sending mine there but I havent had time or cash to do it recently
Old Oct 21, 2007 | 08:03 AM
J's T/A's Avatar
Car: 82 Trans Am
Engine: LTX
Axle/Gears: 3.42 strengthed 7.5 inch
I just put a LS master cylinder on when I changed over to new metric lines. Did a little pushing but certainly didn't need any new lines rebent for it, I had everything off at the time so I just bolted up the prop valve to the M/C and then bent the lines so the holes on the prop valve mounting plate lined up with the holes on the master cylinder.
Now I am sure customs would be easier since then you don't run the risk of cracking or kinking your brake line, but fwiw it can be done with what we have.
Old Oct 26, 2007 | 01:49 PM
Car: 89 IROC
Great......
I wanted something different that stock. I was tinking of either painting the 4th gen piece black (except the resivoir) to have it blend in with the engine bay. Or I may buy the wilwood polished piece.
Just need to make mine a little different that the next guy.
25thannivZ28
Aftermarket Product Review
Jan 2, 2016 05:41 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
87 camaro iroc
Aug 20, 2015 07:47 AM
redmaroz
Aug 16, 2015 11:40 PM
MustangEater82
Brakes
Aug 11, 2015 07:52 AM
