Are all rear disks the same 89 - 02?
Old Oct 14, 2007 | 12:44 PM
Darkshot's Avatar
Car: 91 RS
Engine: 350 TBI
Transmission: WC T5
Axle/Gears: 3.42 Posi
I have stock drum rears and stock fronts. Picked up a rear from a 2000 LS1 F-body and I am trying to figure out what car I should get a proportioning valve from. Does it have to be a 1LE thirdgen car or a standard rear disk car? I plan on doing LS1 fronts sometime also if that makes a difference.
Old Oct 14, 2007 | 01:25 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: Are all rear disks the same 89 - 02?
i needs to be from a disc/disc car, whether its a 1le or not is up to you
Old Oct 14, 2007 | 11:22 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Your disc/drum proportioning vale is the same one used in 89-92 disc/disc setups, so you dont have to change it. 89-97 f-bodies used the same style rear brakes. 98-02 LS1's have a different setup, with an intregal parking brake in the hub. You will need to fabricate a mount for the LS1 parking brake cables as they wont mount to the stock places.. Search this forum for more info.
hectre13
Dec 11, 2023 08:14 AM
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
Warlocksirix
Sep 3, 2015 12:26 PM
Bstrang6
Brakes
Aug 24, 2015 06:45 AM
