rear drum to disc swap - help
Old Oct 17, 2007 | 12:56 PM
92RTripleS's Avatar
Car: 92 RS Convertible
Engine: 383
Transmission: 700R4 Streetfighter
Axle/Gears: 3.73 posi
im working on swapping in a posi rear end from an '84 TA into my 92 RS. what else am i going to have to switch besides the proportioning valve and master cylinder to get the disc brakes to work correctly?
before this, the rear end was in my 82 z28 and it didnt quite work right. the pedal was somewhat weak and often went further to the floor than it should and still didnt stop as well as i think rear disc should.
i wasnt sure if there was a different master cylinder and stuff i should get instead of using the parts off of another '84 TA with rear disc to get the brakes to work better or not. let me know what you think.
thx
Old Oct 17, 2007 | 03:19 PM
ebmiller88's Avatar
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
Re: rear drum to disc swap - help
E-brake cables and either replace the calipers or rebuild them, they're probably stuck solid.
Ed
jaridjohn
Jul 8, 2024 03:49 PM
hectre13
Dec 11, 2023 08:14 AM
Orr89RocZ
Apr 25, 2016 08:28 AM
Scorched1984
Wheels and Tires
66
Apr 16, 2016 06:56 PM
THABADGUY
Brakes
Aug 11, 2015 03:43 AM
