Need help with brakes
Old Oct 20, 2007 | 12:01 AM
83camaroMN's Avatar
Car: 1998 Mustang
Engine: 3.8L V6
Transmission: Automatic with overdrive
Axle/Gears: 2.73:1 axle ratio
Heres the story, A few days ago I was just driving my camaro around town and I went to hit the brakes and it went all the way to the floor I was like WTF now, it still stopped kind of just enough to get me 6 miles back home parked it and let it sit for a few hours.
I came back to take a look at it and the front brake line blew so I go to move it a little bit and the brakes went completely out almost hit a tree, I left it sit where it stopped till I got the parts to fix it.
Got the line in today bled the brakes many many times put everything back together, and when the car is shut off and you pump the brakes it usually builds up pressure well now if I put enough pressure on it it goes right to the floor, so I started it pushed the pedal and it goes right to the floor and with no force, I put the car in gear back up push the petal to the floor and the back brakes locked up but the front do nothing, and also there is no leak anywhere so its not leaking.
What is causing this? could it be the master cylinder going out or what??
Old Oct 20, 2007 | 04:57 AM
ebmiller88's Avatar
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
Re: Need help with brakes
On hell of a sentence..
Since you left it sitting with a broke line, the fluid leaked out and air got into your system. Bleed it until this goes away and it may take you 5-6 times to get it done. If you don't want to mess with it, take it to the dealer and have them pressure/vacuum bleed it for about $35.
Ed
Old Oct 20, 2007 | 01:39 PM
83camaroMN's Avatar
Car: 1998 Mustang
Engine: 3.8L V6
Ed
LOL I was tired and typed it fast.
I bled the front brakes like 10 times and it did not make a difference. And when bleeding there was no air pockets coming out just a steady stream of fluid.
Old Oct 20, 2007 | 06:50 PM
ebmiller88's Avatar
Hmm..I'm thinking there's air in the master, that's my only recommendation.
Ed
BADNBLK
Convertibles
Sep 21, 2015 07:56 PM
dbrochard
Sep 19, 2015 08:13 PM
Necron
Brakes
Sep 14, 2015 12:45 PM
Buickstaged
Brakes
Sep 4, 2015 07:53 AM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:50 PM
