using a disc brake proportioning valve on rear drum brakes?
Old Nov 11, 2007 | 01:16 PM
Jproz1167's Avatar
Car: 1982 Trans Am & 1982 Corvette
Engine: L-98 with LO-3 induction. 350 CFI
Transmission: 5 speed and vette has 700r4
Axle/Gears: 373's in T/A .. vette unknown
the 91 drum rear proportioning valve has a brake line in the wrong place and I am not sure I can bend my original line to get to it. basically my 84 proportioning valve has a line coming out the front and this same line needs to go to the bottom on the 91 proportioning valve. Or could I simply replace the disc proportioning valves spring with the 91 drums spring. Or will the drums work fine with the disc proportioning valve..
need a quik answer on this.
Old Nov 11, 2007 | 01:24 PM
Z28 MeTaL HeAd's Avatar
Engine: Carb'd LT1 w/ a Cam :)
Axle/Gears: Moser 9" w/ 3.75 gears
Re: using a disc brake proportioning valve on rear drum brakes?
This is how its always been. Since 84 all the stock prop valves are the same for the drum cars and all the prop valves for the disc cars are the same (minus 1LE).
You can bend the stock line to screw into the prop valve. It uses the same fitting/threads and everything. All that needs to change is the bending of the rear brake line.
Old Nov 11, 2007 | 01:36 PM
Jproz1167's Avatar
so just use the disc proportioning valve and my drum brakes should work fine?
ZMWojnar
Brakes
May 12, 2019 10:43 PM
Scorched1984
Wheels and Tires
66
Apr 16, 2016 06:56 PM
Reddeath210
Oct 6, 2015 08:20 AM
AkDrifted
Aug 17, 2015 07:45 PM
Jlanz55
Aug 17, 2015 07:15 AM
