B&M Launch control
Old Nov 17, 2007 | 11:21 AM
hwcoll95's Avatar
Car: 1989 Iroc rebuild
Engine: 355 carb'd
Transmission: 5spd
Axle/Gears: 3:08 pos for a while
B&M Launch control
hi all,looking at our setup (disc front ,drum rear) at the combination valve under the master cylinder,we have one brake line to the rear and both front brakes come off the combo valve,the directions show to plug one and install solenoid in other line,then t fitting to both sides?what happens if installed between master cylinder and combo valve(proportioning,metering)
the directions on electrical side are just as confusing,brake pedal switch to hydraulic brake light switch (if needed) WTF? any suggestions,this is for a 5speed beater car for play
Old Nov 18, 2007 | 10:53 PM
hwcoll95's Avatar
Engine: 355 carb'd
Transmission: 5spd
Re: B&M Launch control
no help om a line lock? need to move to drag racing board?
tmellott89
Oct 14, 2015 02:06 PM
Briandrex
Oct 5, 2015 06:20 AM
tattmann
Sep 27, 2015 05:20 PM
Damon
Sep 26, 2015 04:29 PM
