Master Cylinder: Prop Valve Question
Old Nov 18, 2007 | 01:48 PM
Cadillac's Avatar
Car: '91 Firebird Convertible
Engine: 305 TBI (LO3)
Transmission: 700r4, Vette Servo
Axle/Gears: 3.27 9 Bolt, PBR disks
My aging MC is starting to fail in significant ways. Also, I have a new rear axle with PBR disks on it that I plan to swap in replacement of the current drums. I already bought a new master cylinder with the prop valve for the rear disks.
Question:
Can I go ahead and replace the master cylinder with the new one that has the prop valve for rear disks and still use that with the drums?
Does that question make sense?
Old Nov 19, 2007 | 07:57 PM
Cadillac's Avatar
Re: Master Cylinder: Prop Valve Question
TGO, don't fail me now!
Old Nov 19, 2007 | 08:20 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
The drum M/C is correct for PBR's. Check the following link for the info you require:
http://web.archive.org/web/200605221.../1LEbrake.html
JamesC
Old Nov 22, 2007 | 09:13 AM
Cadillac's Avatar
Thanks James!
The situation is that I have a rear axle and PBR's from an '98 GTA sitting in my garage now. I also have a Master Cylinder (Part: 18014287) from GM Parts Direct with the newer prop valve assembly. My current MC is *clearly*going bad.
What I think I am reading in your message is that I cannot replace the old MC with the new one (different prop valve) to run the drums a little while longer.
Sound about right?
69 Six Pack
Oct 5, 2015 07:51 PM
Cameeeero
Sep 18, 2015 04:00 PM
SpaniardV6
Brakes
19
Sep 7, 2015 03:04 AM
redmaroz
Aug 16, 2015 11:40 PM
THABADGUY
Brakes
Aug 11, 2015 03:43 AM
