Hidden braided brake lines
Old Nov 28, 2007 | 10:52 PM
racing geek's Avatar
Car: 1987 IROC-Z
Engine: 383 with Edelbrock ProFlow EFI
Transmission: TH350
Axle/Gears: 12 bolt 3.73 Eaton posi
I was thinking about a way to hide the braided lines but still have visible lines. What if you spray painted your braided lines flat black and then used some of that skrink wrap stuff that shrinks when it is heated. It would still look like a rubber brake line but provide better brake feel due to the hidden braided line. I can't imagine the brake line would look much larger. Any comments?
The only thing I can think of that might be wrong with this is the shrink stuff might crack and fall off.
Old Nov 29, 2007 | 05:24 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: Hidden braided brake lines
May I ask why?
JamesC
Old Nov 29, 2007 | 07:24 AM
Stephen's Avatar
Car: 87 GTA
Judging by his autocross pic in his sig, I'm guessing he wants to go SS brake lines, but they aren't legal in his class, so wants to hide them. Did I get it right, racing geek?
Old Nov 29, 2007 | 08:46 AM
I H8 WWD's Avatar
Car: 89' IROC-Z
Engine: LO3
Axle/Gears: 10-Bolt/2.73
Try this.
NOTE: Recovered ID is after its heat shrunk. So make sure its the correct size AFTER shrinking.
http://www.aedwis.com/coleflex.html
Old Nov 29, 2007 | 03:23 PM
Car: 1987 IROC-Z
Transmission: TH350
Yes, and it would also help the sleepers out there get another edge.
Old Dec 2, 2007 | 10:55 AM
nape's Avatar
Car: American Iron Firebird
Engine: The little 305 that could.
Transmission: Richmond T-10
Axle/Gears: Floater 9" - 3.64 gears
Just zip tie 1/4" rubber hose over it.
We do it for more protection from flying debris and rubbing.
Old Dec 3, 2007 | 05:50 AM
SilentNight1647's Avatar
Or you could cheat and use covered braided hydraulic hose like I do. The stuff is black and has a soft braided cover over the stainless core. It's also dirt cheap from hydraulic shops and will hold up just as well as any braided brake line.
Frozer!!!
Jan 19, 2024 04:55 PM
355tpipickup
Alternative Port EFI Intakes
Aug 26, 2015 04:08 PM
MustangBeater20
Carburetors
Aug 21, 2015 02:42 PM
Leggman1
Brakes
Aug 12, 2015 08:39 PM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
