Front Brake Piston Diameter?
Old Jan 2, 2008 | 08:22 PM
Neil87Z28's Avatar
Car: 1987 IROC Z28
Engine: 427ci
Transmission: TH350
Does anyone know the diameter of the brake caliper piston for the stock 10.5" front brakes?
Thanks.
--Neil
Old Jan 2, 2008 | 10:16 PM
ebmiller88's Avatar
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
Re: Front Brake Piston Diameter?
2.5"
Ed
Old Jan 2, 2008 | 11:13 PM
Neil87Z28's Avatar
Car: 1987 IROC Z28
Engine: 427ci
Transmission: TH350
Thanks Ed. Are the C5 calipers 40mm x 2? I'm trying to figure out the hydraulic ratios and how they will change when I swap the brakes for the C5s.
Old Jan 4, 2008 | 08:39 AM
ebmiller88's Avatar
Either 40 or 41, they're the same as 1LE piston diameter so if you use a disc/drum master you'd be fine hydraulically.
Ed
Frozer!!!
Jan 19, 2024 04:55 PM
Scorched1984
Wheels and Tires
66
Apr 16, 2016 06:56 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
Dialed_In
Aug 20, 2015 01:45 PM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
