rear baer track claw question
Old Jan 5, 2008 | 08:26 PM
topless89's Avatar
Car: 89 RS Convertible
Engine: 305 tbi
Transmission: 700R4,B&M friction,Transgo shiftkit
Axle/Gears: 2.73 LSD
i just installed a set of 12" track claw discs on my 89 rs vert. i couldn't be happier with the improvement over drums there's a big difference even with the 13" set up in front. but after a few shake-down runs i noticed some unusual sounds. i pulled the calipers and found scoring marks on the calipers. the kit installs with some washers between the caliper and mounting bracket so i tried moving the washers to the other side of the bracket to change the position of the caliper. when i tested them again the other side of the caliper contacted the rotor while cornering. has anyone else used this setup and had similar results?
Old Jan 5, 2008 | 09:04 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: rear baer track claw question
No experience with Baer; however, a shim (or thinner washer) may be required to center the caliper over the rotor. Check the following link for more info:
https://www.thirdgen.org/forums/faq-...iscs-89-a.html
JamesC
Scorched1984
Wheels and Tires
66
Apr 16, 2016 06:56 PM
86White_T/A305
Aug 17, 2015 12:16 AM
redmaroz
Aug 16, 2015 11:40 PM
Feffman
Mid-West Region
Aug 13, 2015 07:12 AM
Feffman
Aug 13, 2015 07:11 AM
