Cleaning up calipers
Old Feb 11, 2008 | 05:47 PM
black_highway's Avatar
Car: 91' RS Camaro
Engine: 305c.d. Toilet Bowl Injection
I'm having trouble cleaning up my rear PBR's, does anyone have any good tips on cleaning these guys up? The grime is stuck on pretty good! Any help is greatly appreciated!
Old Feb 11, 2008 | 07:24 PM
Poltergeist's Avatar
Car: 2002 Camaro SS / 1982 El Camino
Engine: LS1 / LT1 in the El
Transmission: A4 in both
Re: Cleaning up calipers
I've used brake cleaner and a metal brush with success.
Old Feb 12, 2008 | 05:23 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
I use wheel cleaner and a brush once or twice a year.
JamesC
Old Feb 12, 2008 | 10:15 AM
gearhead0384's Avatar
Car: 1989 Camaro IROC-Z
Engine: L98 350 TPI
Transmission: Built TH-700 R4 (Vilgilante 2800)
Axle/Gears: 9 bolt w/ PBR's
I used Wheel Acid "wire wheel cleaner". I got it from one of the detailers at work and it eats through any kinda dirt.
Kevin
Old Feb 12, 2008 | 02:41 PM
Car: 91' RS Camaro
Thanks for the tips guys. I'll be trying that now, as Purple Power, Carb Cleaner and a wire brush have so far failed.
Old Feb 13, 2008 | 06:41 AM
ebmiller88's Avatar
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
If you can tear them all the way down have them media blasted but be sure to plug the piston bore and cover the banjo bolt sealing surface to keep them from getting scored. That works wonders, then repaint them with an aluminum color paint.
Ed
manualbrakes.com
Brakes
63
Apr 9, 2024 11:55 AM
gta892000
Aug 11, 2019 11:16 AM
sailtexas186548
Feb 17, 2017 03:07 PM
350 IROC-Z
Camaros Wanted
Dec 18, 2015 03:58 PM
87v6Bird
Brakes
Oct 4, 2015 07:37 AM
