Ls1 Proportioning valve help
Old Feb 12, 2008 | 06:37 PM
seiplentz's Avatar
Car: 85 Z28
Engine: GMPP 350 HSR
Axle/Gears: 4th gen 3.42 Posi LS1
I just bought a 99 Ls1 rear to swap into my car basically for the brakes.
I found some confusing answers about the brake pressures for disk brakes.
I am trying to get all the parts I need to do the swap. So my question is do I need more or less line pressure to the rear for the drum to disk swap.
I would to be able to adjust it with an adjustable prop valve but from what I have read it seems like I need to replace the whole valve.
It doesn't need to be easiest fix, I want to have the best results from this swap.
So whoever has had good results what did you use?
dbrochard
Sep 19, 2015 08:13 PM
355tpipickup
Sep 13, 2015 11:35 PM
sandman92084
Sep 12, 2015 10:27 PM
Nick McCardle
Sep 10, 2015 08:36 PM
