pbr,s not working
Old Mar 13, 2008 | 01:22 PM
monoply6's Avatar
Car: 89 trans am gta
Engine: 5.7
Transmission: auto
Axle/Gears: 9 bolt
pbr,s not working
hi all the rear cailers do not have much holding power i had new pads put on about 800 miles on them they need to be aleast 16% but struggled to get 4% out of them when tested does any one no what could be the cause of this thanks
Old Mar 29, 2008 | 11:26 AM
Azrael91966669's Avatar
Car: 1991 camaro RS
Engine: CharlesOdoryOB
Transmission: 82513892892
Axle/Gears: pbr disc 3.27 nine bolt
Re: pbr,s not working
im haveing the same issue ever since i did the rear end swap
Old Mar 29, 2008 | 02:09 PM
afremont's Avatar
Car: 90 IROC
Engine: 5.7 TPI
Transmission: 4L60
After sitting for about 6 years mine didn't want to work anymore. On jack stands, they couldn't hold the rear wheels from spinning in drive at fast idle. I'm rebuilding them now (actually waiting for the paint to dry before reassembly) to see if they will work again. The pistons were pretty well stuck in the bore seal, but no corrosion. 90PSI could barely push them out.
Rebuild kits are like $11.50 each, but there's allot of pieces in the kit. The emergency brake feature wins a Rube Goldberg award in my book. The whole thing is a pretty complex design for a single piston POS caliper that doesn't work as good as the cast iron one up front.
Don't forget the hoses, they seem to be a common source of problems with these cars.
Old Mar 29, 2008 | 02:57 PM
monoply6's Avatar
Engine: 5.7
Transmission: auto
Axle/Gears: 9 bolt
hi thanks for responding do you no the best place to buy the rebuild kit and pipes not to easy to get hold of here in thr uk thanks
Old Mar 29, 2008 | 09:23 PM
TF34MECHH's Avatar
Car: 90 RS
Axle/Gears: 2.77
I have been looking for hoses for mine as well. Advanced has several brands
and numerous part numbers. They have Tru Torque, Bendix, and Raybestos
and many different numbers. Which ones are a good deal for the rear disc of
a 89 Camaro? Are the left and right actually different?
Old Mar 30, 2008 | 08:12 AM
afremont's Avatar
Car: 90 IROC
Engine: 5.7 TPI
Transmission: 4L60
I bought my hoses thru o'reilly, but they should be available thru any supplier. Napa actually had lower prices, but they didn't have them in stock.
Yes, the left and right hoses have different part numbers. Don't forget that there is a center hose for the rear too.
Old Mar 30, 2008 | 11:51 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Originally Posted by TF34MECHH
I have been looking for hoses for mine as well. Advanced has several brands and numerous part numbers. They have Tru Torque, Bendix, and Raybestos and many different numbers. Which ones are a good deal for the rear disc of a 89 Camaro? Are the left and right actually different?
They are different. Check the following link for pics and part numbers. Also check the info on "free travel":
https://www.thirdgen.org/forums/faq-...iscs-89-a.html
JamesC
Jake_92RS
Jan 28, 2020 10:37 PM
ZMWojnar
Brakes
May 12, 2019 10:43 PM
Eric-86sc
Apr 3, 2016 03:52 PM
Fronzizzle
Aug 17, 2015 02:52 PM
THABADGUY
Brakes
Aug 11, 2015 03:43 AM
