1LE & C5 upgrades
Old Mar 14, 2008 | 11:46 AM
cdamiano's Avatar
1LE & C5 upgrades
Im looking to upgrade my stock fronts to a 13" rotor. I know the c5 kit is the way to go. Here's my problem. Many companies are selling a c5 upgrade kit using modified stock spindles. Putting all that extra mass (rotors, wheel & tire) on stock bearings. Now the factory 1LE uses larger bearings, correct? Is there any way to get the c5 13" rotor/caliper set up on a 1LE spindle, so I have loose larger bearings.
Any thoughts?
Old Mar 14, 2008 | 03:35 PM
Re: 1LE & C5 upgrades
The ID of the bearings for the 1LE setup is the same as the ID of the bearings for the Saginaw setup. All you have to do to "modify" regular spindles to accept the 1LE calipers, is cut off 2 ears, and drill & tap 2 holes. No change to the bearing area.
Old Mar 14, 2008 | 04:32 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Though the ID is the same, there is a size difference. Check PartsAmerica, for exampe, for more info.
JamesC
Old Mar 14, 2008 | 05:18 PM
Right: OD is different for at least one of the 2 bearings; but the ID (the spindle side) is the same.
So, "all that extra mass", is not an issue.
Old Mar 14, 2008 | 05:37 PM
cdamiano's Avatar
So if i understand correctly, the only difference in the spindle is the mounting location for the caliper. The actual machined portion of the spindle is the same as the stock spindle.
Old Mar 14, 2008 | 06:08 PM
JamesC's Avatar
Yes. Check the first link in the following thread for pics/info:
https://www.thirdgen.org/forums/faq-...iscs-89-a.html
JamesC
Old Mar 15, 2008 | 11:49 AM
cdamiano's Avatar
Old Apr 19, 2008 | 07:48 AM
3rdGenWillie's Avatar
Car: 92 Lo3 RS
Engine: 305 roller tbi
Transmission: t-5
Axle/Gears: 3.08 open
At parts store, when i asked for wheel bearings they asked if it was for the perfromance package. they had performance inner & outer. 1992 RS V-8 all had same handling package. what would the performance bearing be? i got the reg. federal mougol ones. size difference? for larger rotor/spindle?
Old Apr 19, 2008 | 05:59 PM
JamesC's Avatar
If you have dual piston alum calipers, you have the performance package. Here's what the look like:
https://www.thirdgen.org/forums/atta...89-fbrake2.jpg
JamesC
gta90
Sep 15, 2015 04:00 PM
Necron
Brakes
Sep 14, 2015 12:45 PM
ANDYZ28
Brakes
105
Jun 8, 2009 09:50 PM
'91 Formula
May 16, 2002 10:15 PM
ANDYZ28
Feb 21, 2002 07:46 PM
