1LE Proportioning Valve
Old May 15, 2002 | 09:04 PM
'91 Formula's Avatar
Car: 1991 Firebird Formula
Engine: 383 Supercharged and Intercooled
Transmission: 6-Speed
Axle/Gears: Stock 10 bolt 3.42
Must the proportioning valve be changed, to the 1LE version, when upgrading Front brakes to 1LE? I have a 1991 Formula with the stock 1LE rears.
I don't think they give you a new proportioning valve when you buy Baer or SSBC kit's, so why would you need it ifor the 1LE conversion?
Old May 15, 2002 | 09:13 PM
ebmiller88's Avatar
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
Read:
https://www.thirdgen.org/techbb2/sho...threadid=59878
From the above:
2)Do I need to get a different proportioning valve? YES. The 1982-1989 (1st design) cars will need GM part# 14089496. The 1989 (late 1989 2nd design) cars will need GM part# 10136840 (which is now 10164112). The 89-92 cars with 4WD brakes already have the correct proportioning valve. After you have done your 1LE front brake upgrade, a quick test drive will verify this.
There ya go.
Old May 16, 2002 | 06:47 AM
Great thanks. I guess I should have looked at that post first.
Old May 16, 2002 | 10:15 PM
ebmiller88's Avatar
PurelyPMD
May 5, 2016 04:57 PM
87v6Bird
Brakes
Oct 4, 2015 07:37 AM
Necron
Brakes
Sep 14, 2015 12:45 PM
355tpipickup
Sep 13, 2015 11:35 PM
sandman92084
Sep 12, 2015 10:27 PM
