Caliper seizing up
Old Apr 2, 2008 | 01:32 AM
netfreak's Avatar
Car: 88 firebird
Engine: 305 TBI
Caliper seizing up
So my front passenger caliper seems to lock up after hard braking.. Figuring it was the caliper itself, I replaced it. Same thing still happening. Could this be an issue with the master cylinder? Any other ideas?
Old Apr 2, 2008 | 04:20 AM
TF34MECHH's Avatar
Car: 90 RS
Axle/Gears: 2.77
Re: Caliper seizing up
It sounds like one of your brake hoses is collapsing.
Old Apr 2, 2008 | 05:20 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
https://www.thirdgen.org/forums/faq-...ulls-side.html
JamesC
Old Apr 2, 2008 | 06:42 AM
UNCLE TOM's Avatar
Car: 91 R/S , 89 dodge p/u
Engine: L31 GM crate re-cammed , 318
Transmission: T-5 , 4 speed auto
Axle/Gears: 3.42 , ?
happened to me . i would change both front lines . also they are keyed specific for lt. & rt. application . good luck .
Old Apr 2, 2008 | 02:36 PM
netfreak's Avatar
Car: 88 firebird
Engine: 305 TBI
Ah cool, doesn't sound too bad. I'll pick up some new lines shortly as they did appear to be the original ones. What are the chances that the metal lines in the engine bay would need replacing?
Old Apr 2, 2008 | 03:06 PM
UNCLE TOM's Avatar
metal lines should be o.k. , just look them over for rust pits road damage . should be o.k. . good luck .
Old Apr 2, 2008 | 09:50 PM
netfreak's Avatar
Car: 88 firebird
Engine: 305 TBI
THANK YOU FOR THE SUGGESTIONS ON THE BRAKE LINES!!! I just finished replacing it and OMGWTFBBQ my car drives straight again, plus my brake pads don't bloody light on fire. I was heading out for dinner tonight and smoke started pouring out from my brakes... They must have grabbed real good after I had to do some hard braking. Rushed to the parts store (in second gear doing 50kph so I wouldn't have to use my brakes often) and got the new line. Daaaamn its nice when things work out.
Old Apr 4, 2008 | 05:01 AM
InfernalVortex's Avatar
Car: 1992 Camaro RS
Axle/Gears: 9-bolt 3.70
This is important! I even knew that and managed to get my left and right confused anyway, and I spent something like 30 minutes screwing around with it trying to figure out why the hell it wasnt going in right.... FInally revisited my old assumptions and had a terrifying thought.
Some mistakes you only need to make once.
Also, for the record, for anyone replacing brake lines, go ahead and replace the calipers too. Once you're there with the line off, it's SO easy to pop the new caliper in and they're a whole $10 each with a core. Unless you've got those crazy 1LE front brakes in which case you're on your own!
Old Apr 4, 2008 | 05:18 AM
JamesC's Avatar
I beg your pardon !
JamesC
manualbrakes.com
Brakes
63
Apr 9, 2024 11:55 AM
AmpleUnicorn88
Brakes
32
Nov 18, 2015 11:02 AM
BADNBLK
Brakes
Oct 6, 2015 02:51 PM
87v6Bird
Brakes
Oct 4, 2015 07:37 AM
the_hamturdler
Sep 30, 2015 12:50 PM
