do baer replacement pads exist?
Car: 86 sport coupe, 89 IROC-Z
Engine: 5.7 TPI, 5.0 TPI
Transmission: T-5, T-5
Axle/Gears: drum posi 3.73, disc open 2.73
I have an 89 iroc with a baer brake sport kit (drilled&slotted 11" rotors with 2piston calps + adapter hubs). The previous owner had recipts with a kit # 130143. The Baer site no longer carries this kit #. Is this a retro 4th gen sytle system? All Im looking for is replacement pads. Any help would be great. Also, can drilled rotors be refinished?
Engine: 4++,350 & 305 CIs
Re: do baer replacement pads exist?
Im sure they do. Gm also has them.
Car: 89 RS Convertible
Engine: 305 tbi
Transmission: 700R4,B&M friction,Transgo shiftkit
Axle/Gears: 2.73 LSD
Baer usually uses the 2 piston PBR calipers. The pads should be available everywhere, listed under 88-92 camaro w/performance brakes if your kit uses the PBR's.
Vintageracer
Aug 11, 2015 08:13 PM
