REAR DISK HOLDING POWER
Old May 5, 2008 | 07:59 PM
drperformance's Avatar
Car: 1987 firebird
Engine: 1995 lt1 383
Transmission: 4l60e
Axle/Gears: moser 9" with 3.70
I swaped rear ford explorer brakes (ford 9" rear end) on my 87 firebird that had rear drums. I swapped the proportioning valve from a 92 that had 4 wheel disks and changed the threads. Now I am not sure but it seems as if I hardly have rear brakes. I have not put the car on the ground or taken it for a ride yet, but on jack stands I can hold the brake as hard as possible and rev the car and the axels start turning at about 1000-1200 rpm does this seem low? Should I change out the master to the 4 wheel disk one that has a .05" bigger rear piston?
I bled everything: master,foot bled, vacuum bled, and gravity bled.
Please help I have a race coming up this Saturday and need to get the car on the road.
Old May 6, 2008 | 11:40 AM
Car: 1987 firebird
Transmission: 4l60e
Re: REAR DISK HOLDING POWER
any one?
Old May 6, 2008 | 12:28 PM
Guest
Guest
Posts: n/a
Might be low.
Go drive the car and break in the pads and rotors and see how they are then.
Old May 7, 2008 | 10:26 AM
spills's Avatar
Car: 89 RS
Engine: 6.3L Megasquirted HSR
Axle/Gears: 3.70 Posi 9 bolt
might be best to ditch the stock prop valve and get an adjustable. Maybe the Ford brakes have different pressure ratings/specs and need to have adequate pressure to them to work properly. Or maybe you still have a little air in the lines. Id try re-bleeding them again, try pumping about a half bottle or so worth of fluid out through the bleeders. If you do ditch the stock prop valve though, let me know. I need one for my LS1/PBR swap
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
MoJoe
Fabrication
Aug 19, 2017 07:12 PM
86White_T/A305
Aug 17, 2015 12:16 AM
stalkier
Aug 13, 2015 12:59 PM
