Master cyl/fire wall brace?
Old May 7, 2008 | 12:46 PM
ls six's Avatar
I did some searching and had no luck finding any parts or info.
Dose any one know of a supplier for these braces?
The master cyl/booster assembly on my car moves a lot under normal use and a brace would be a huge improvement.
Old May 7, 2008 | 02:24 PM
jaykar's Avatar
Car: 87 Iroc Showcar - Saturday Nite Hun
Engine: 383 4-Bolt Truck Hyd Roller MiniRam
Transmission: B&M 700R4 - Edge 3200
Axle/Gears: BW 9 Bolt-TA Cover & Stud Kit - 3.2
Re: Master cyl/fire wall brace?
Bolts loose behind firewall??
Cracked firewall around booster mount??
If not, would be easy to fab up a brace if needed.
Did car have one originally??
Compare similar car.
Later
Old May 10, 2008 | 11:05 AM
ls six's Avatar
Nope everythings tight and in one piece.
I can do it my self ofcourse but if somone else has done the work allready or has a better design then I'd go that route.
Hopefully when I install new struts/shocks and remove the stupid blocks from the rear springs the car will ride better and stop shuddering and flexing so much.
It's not just the master cyl moving and proabably affecting pedal feel the whole car just feels like it's about to fall apart.
I never realised just how solid my mazda was untill I bought this car lol.
Old May 10, 2008 | 01:35 PM
jaykar's Avatar
Sub Frame Connectors.
Strut Tower Brace.
Later
Old May 11, 2008 | 12:53 AM
kcb37's Avatar
These cars are not ment to ride smoth in any sense.
Make sure you bolts are tight, and also that your bolt holes aren't oblong.
Something seems to be not tight or worn out.
If you have someone in the car and hit the brakes does the booster move?
What makes you think the booster is moving?
Old May 11, 2008 | 01:02 PM
jaykar's Avatar
Out of curiosity,
Whats the 2 speed trans all about
Powerglide
Later
Old May 11, 2008 | 02:33 PM
ls six's Avatar
Well I'm sure that it'll ride much better when I remove the spring blocks somone used to lock half of each rear spring together.
I know the booster is moving because i had the hood up when backing up the ramps to check out the rear end. The tip of the MC moves up about a half inch before the brakes will lock up.
Originally Posted by jaykar
Out of curiosity,
Powerglide
Later
Nope. Broke 700R4
Old May 12, 2008 | 03:31 PM
jaykar's Avatar
Actually you now have a 350R4
Later
Old May 12, 2008 | 06:37 PM
ls six's Avatar
Later
Huh?
Old May 12, 2008 | 06:52 PM
jaykar's Avatar
700/4speed devided by current 2 speed = 350
Later
Old May 12, 2008 | 07:10 PM
ls six's Avatar
Ahh lol. I didnt want to be a **** and point out that the 350 was a 3 speed.
I figured I was missing somthing lol
RedLeader289
May 28, 2019 01:47 PM
Fireslash
Apr 11, 2016 06:43 PM
jaridjohn
Oct 5, 2015 07:01 AM
meeklay812
Oct 1, 2015 03:46 PM
SS-EXPRESS
Sep 28, 2015 09:14 AM
