brake light on dash...
Old May 8, 2008 | 09:00 PM
Avernus's Avatar
Car: 1988 Iroc-z28
Engine: 5.7 350
Axle/Gears: 2.77
So i have the brake light on, on my dashboard. I had the console off a few days ago could i have unhooked a wire or does it mean something else. I put some brake fluid in and it's plenty full.
Old May 8, 2008 | 09:43 PM
Al Hasse's Avatar
Car: 1992 RS / 1989 RS
Engine: 3.1L MFI / Vortec 383 TBI
Transmission: T5 / LS-T56
Axle/Gears: 3.42 open / 3.73 Eaton posi
Re: brake light on dash...
Could have pinched the copper trace on the mylar circuit board on the back of the cluster. I did the same thing and found the trace next to the light was pinched against a ground trace.
Old May 11, 2008 | 04:18 AM
Avernus's Avatar
Car: 1988 Iroc-z28
Engine: 5.7 350
Axle/Gears: 2.77
Thanks i'll check that!
Old May 13, 2008 | 01:00 PM
squirted1's Avatar
Car: 84 Trans Am
Engine: 383
Transmission: Tremec TKO
Axle/Gears: 10 bolt 3.73 lsd
also check to see if the wire conn. came off of the e-brake switch. IIRC this will turn on the light.
Old May 13, 2008 | 05:44 PM
Al Hasse's Avatar
That's just a ground wire that completes the circuit when the e-brake handle is pulled. There's no place for the ground to go if it's disconnected, on the other hand, if its shorted against something.... Been through that hassle trying to figure out why my hatch wouldn't release...
wbrooks63
Exterior Parts Wanted
Oct 4, 2015 08:40 PM
SpaniardV6
Brakes
19
Sep 7, 2015 03:04 AM
stalkier
Aug 21, 2015 01:54 AM
stalkier
Aug 13, 2015 12:59 PM
Omega
Aug 10, 2015 12:46 PM
