hatch 3rd brake light?
Old May 12, 2008 | 05:22 AM
xurusaibobx's Avatar
Car: 1991 Camaro RS B4C
Engine: 5.7 350 TPI
i just picked up a 91 camaro and the top mount 3rd brake light doesnt seem to be working. i opened it up and the bulb is still good as i can tell. where do i start to hunt down the problem?
heard it was common?
Old May 12, 2008 | 06:55 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: hatch 3rd brake light?
What happens is that the socket melts & deforms. Had the same problem, no 3rd light, so replaced the bulb. Still no light, and the original bulb was still good.
What I ended up doing was to bend the pins on the bulb (if I remember this correctly, it has been a while). And inserting the bulb so that contact was made. Moved the bulb & pins around until it worked.
RBob.
Old May 12, 2008 | 09:25 PM
Engine: 5.7 350 TPI
thanks! the bulb wasnt making good contact with the connector ..anyone modified this to make a different size bulb work? led maybe?
Old May 12, 2008 | 11:30 PM
krisb410's Avatar
Car: 91 RS Camaro, 75 L82 Corvette
Engine: LO3, 383 Stroker
Transmission: 700R4, TH400
Axle/Gears: 4th gen 3.23 posi/LS1 discs, stock
I got a LED replacement. Cheaper than buying a replacement.
Just order the update kit, you can reuse your current housing. I even put my the red lens back in, so it looks stock.
Click on the picture.
Old May 13, 2008 | 01:44 AM
Engine: 5.7 350 TPI
thanks i just ordered it
Old Jun 27, 2008 | 12:17 PM
92RSsleeper's Avatar
Car: 92 Camaro
Engine: 404 SBC
Transmission: The strongest stock T5 ever made
Axle/Gears: 3.73 w/Detriot Tru Trac Locker
where'd u guys order yours from?
I'd also like to try to get the stock one to work first, if bending the pins on the pulb etc doesnt work, where do the wires lead to? i see they run above the headliner in my car...
Old Jun 27, 2008 | 03:02 PM
krisb410's Avatar
CLICK ON THE PICTURE, it is a link to the guy making these kits.
Old Jun 30, 2008 | 06:53 PM
chevyowner02's Avatar
Car: 1992 camaro
Axle/Gears: 3:73
He's a good guy to deal with also he has fixed mine a bunch of times for the charge of shipping.
Old Jun 30, 2008 | 09:32 PM
Car: 92 Camaro
Engine: 404 SBC
oh thanks kris, sorry i didnt see the "click on the picture" from ur first post
back to the problems though...does anyone know where the wires lead to then? cuz im almost positive the whole setup works, i think the problem may be closer to the front of the car.thanks
Vintageracer
Jan 10, 2020 05:33 PM
wbrooks63
Exterior Parts Wanted
Oct 4, 2015 08:40 PM
Eagle223usa
Brakes
Aug 14, 2015 09:24 AM
stalkier
Aug 13, 2015 12:59 PM
Omega
Aug 10, 2015 12:46 PM
