Brake Questions
Old Jun 3, 2008 | 09:29 PM
Chitown1818's Avatar
Brake Questions
Hey guys i had a couple questions and couldnt really find the right answer. I ended up bending my axle shaft so ive come across a rear end even though its a lower gear not a big deal. but i have originally stock drum brakes in the rear. the new rear end has disc brakes. will my master cylinder and line work ok with this setup or do i have to upgrade, change lines? any help would be greatful. thanks
jon
Old Jun 4, 2008 | 06:14 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: Brake Questions
Mentioning the year, make, and model of your car is helpful when asking questions. Generally speaking, the master should be ok. I'd swap the prop valve. You'll also have the change the drive/driven gears for the speedo to read correctly. If you have a T5, read the stickies.
JamesC
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
SpaniardV6
Brakes
19
Sep 7, 2015 03:04 AM
redmaroz
Aug 16, 2015 11:40 PM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
