Disc brake conversion
Old Jun 4, 2008 | 02:26 PM
Squiernmr's Avatar
My 92 camaro RS came with drums brakes in the rear and fairly small discs up front. I was wondering how hard is it to convert drums to discs and how much would all the parts be including 4 drilled rotors and larger calibers?
Old Jun 4, 2008 | 02:48 PM
safemode's Avatar
Car: camaro rs
Engine: 305 tbi and 350 on stand
Transmission: 4spd auto
Re: Disc brake conversion
It's really easy if you just swap to an entire rear that already has disc brakes.
calipers, all depends on what you're looking for. anywhere from a couple hundred for a simple 9bolt non pbr swapin to thousands of dollars for crazy 1000hp setups. The most annoying thing you'll probably have to deal with is flaring the brake lines, and if you go with non-stock, adjusting the line flow.
Old Jun 4, 2008 | 03:00 PM
89transam*pearl's Avatar
Car: 89 T/A
Engine: LB9
Transmission: W/C T-5
Axle/Gears: 10 bolt posi, 3.73 Richmond Gears
Hawk's has a conversion kit for around a $1,000 bucks.....ouch !!
Old Jun 4, 2008 | 03:15 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
At least the first portion of your question is one that's asked bi-weekly. A search will provide the info you require. You might start with the following link:
https://www.thirdgen.org/forums/brak...drum-rear.html
JamesC
Originally Posted by safemode
The most annoying thing you'll probably have to deal with is flaring the brake lines...
Generally, there's no need to reflare lines. It's a simple bolt-up..
Old Nov 12, 2008 | 10:07 PM
Squiernmr's Avatar
hey Ed. I live in NYC so its kinda hard to get my whole ear out in the street. You think its possible to do the drum to disc swap without removing the rear or axles? if so, can you maybe explain that process. Thanks a lot
Old Nov 13, 2008 | 06:28 AM
JamesC's Avatar
Not Ed, but in answer to your question, no. Check the following link to Ed's site, and you see that the axles must go through the brackets:
http://www.flynbye.com/catalog/i30.html
The following link shows how to remove the axles:
https://www.thirdgen.org/forums/tran...ing-axles.html
JamesC
Old Feb 28, 2011 | 06:07 PM
BIG WIG's Avatar
Car: 1989 camaro
Engine: 454
Transmission: turbo 400
Axle/Gears: 9 "/3:73
the kit i got with my 9" came with disc brake upgrade ,but how do you get the camaro brake lines ( metric ) to work with standard thread calipers ?
scottmoyer
Sep 7, 2015 07:06 PM
84 TA NV
Sep 6, 2015 08:02 PM
!CamaroDave
Members Camaros
Sep 5, 2015 10:39 AM
Buickstaged
Brakes
Sep 4, 2015 07:53 AM
rudolphschenker
Sep 4, 2015 02:41 AM
