I'm guessing this is the problem
Old Jun 9, 2008 | 07:29 PM
oifish's Avatar
Car: 1992 Camaro Z28
Engine: 5.7 TPI L98
Hey all. So if I suddenly hit the brakes the car swerves to the left. I'm pretty sure the idiot that had the car before me warped the rotors when he replaced them. My first question is what should I look for before replacing the rotors. And the second is what type of rotors should I get if they do need to be replaced (I know nothing about brakes)? I have stock 92 Z28 wheels.
Old Jun 9, 2008 | 07:40 PM
CaliChevyLover's Avatar
Car: 1986 IROC-Z28
Re: I'm guessing this is the problem
if they are not warped too much you might be able to get them resurfaced. but if not the replacement rotors i got from autozone work great. bought new calipers from them also...they work great but completely rusted over about 2weeks after i put em on. same with the rear drums i replaced
Old Jun 9, 2008 | 08:36 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
On 3rd gens this is typically caused by the front brake hoses. The flexible ones that run from the frame to the caliper.
If a normal application of the brakes causes no pulling, but a jab on the brakes causes the car to change lanes, front brake hoses are the best bet.
RBob.
Old Jun 9, 2008 | 08:39 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
JamesC
Old Jun 9, 2008 | 09:20 PM
ws6transam's Avatar
Car: 1984 Trans Am WS6
Engine: Minirammed 385, 396 RWHP
Axle/Gears: 3.73 Moser 12-bolt
Do the brake hoses first, then bleed the brakes and change out all fluid.
Then if it still swerves, then it's corroded pistons. Go buy some remanufactured calipers. Warped rotors cause pulsing, not necessarily swerving.
However chances are it is the flexible lines. Those go bad after seven years if you are not changing the fluid every 36 months.
92camaroJoe
Jul 29, 2023 07:57 PM
chazman
Aug 28, 2018 03:25 PM
Cleotiz
Jan 6, 2018 08:56 PM
chazman
Aug 22, 2015 02:01 PM
92camaroJoe
Aug 13, 2015 06:07 AM
