All calipers leaking...
Old Jul 16, 2008 | 04:17 PM
john1784h@yahoo's Avatar
I have new (remaned) calipers on all four wheels. The rear are PBR for the 9 bolt BW, and I have the correct prop valve for the rear (which was swapped in). The fronts are just a standard caliper. The lines are rubber, not original, but not new, I think they are 4-5 years old. All the other caliper hardware is new.
I have never driven with these guys, I install them and go to bleed them and they are leaking everywhere, and are still leaking. I can't think how its possible as the lines are fitted tight to the calipers and they all have new crush washers. No leaks around the master cyliner or prop valve.
Any ideas? Please help!
Old Jul 16, 2008 | 04:19 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: All calipers leaking...
Where are they leaking from?
Old Jul 17, 2008 | 09:03 PM
Seems to be where the brake line meets the caliper. Lots of brake fluid everywhere.... All this stuff is new too.
Old Jul 17, 2008 | 09:15 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Sounds like you haven't crushed your washers enough.
Old Jul 19, 2008 | 08:33 AM
I have everything on there pretty tight. But I'll give it a try. Thanks.
Old Jul 19, 2008 | 02:45 PM
86camaro383's Avatar
Car: 86 Iroc
Engine: 383
Transmission: TH350
Axle/Gears: 3:73s!
Do you have a washer on each side of the brake hose? There copper washers correct?
manualbrakes.com
Brakes
63
Apr 9, 2024 11:55 AM
AmpleUnicorn88
Brakes
32
Nov 18, 2015 11:02 AM
BADNBLK
Brakes
Oct 6, 2015 02:51 PM
87v6Bird
Brakes
Oct 4, 2015 07:37 AM
the_hamturdler
Sep 30, 2015 12:50 PM
