Vacuum reserve question
Car: 87 Trans Am GTA
Engine: 5.7L TPI
So I've just about decided to go with a vacuum reserve canister to offset my poor braking abilities with my motor setup, but I have a question. Do I need to run a "special" canister like Jegs', Summit's, or Comp Cam's, or can I use any canister that can hold a vacuum? I was gonna retrofit a reserve from another vehicle, like one of these:
http://www.napaonline.com/MasterPage...on=Vacuum+Tank
Will these suffice? Thanks guys.
Engine: 5.7L TPI
Re: Vacuum reserve question
Thanks, just wanted to make sure I wasn't missing something in those overly expensive canisters. $60 for a coffee can with fittings.
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
so long as it has a check valve it will be fine
thefirebirdm@n
South Central Region
Sep 14, 2015 01:45 PM
