parking brake "coupler"
Old Jul 25, 2008 | 12:30 AM
gorbilax's Avatar
Car: 1992 Firebird
Engine: 3.1L LH0
i was recently given a 92 firebird and am slowly trying to get it on the road. I took it today for state inspection and the mechanic failed the parking brake coupler. I got under the car today and traced the lines from the rear brakes up to the bracket that joins them to the cable that runs up to the front of the car. the edge of the bracket is bent. I don't know why this constitutes a failure, because my parking brake works fine, but i need to find a new one of these couplers from somewhere. I'm also not quite sure how to remove it either. any thoughts? thanks...
Old Jul 25, 2008 | 12:37 AM
86NiteRider's Avatar
From: Somewhere around the South Side of Chicago just crusin' in one of the Niteriders
Car: 92RS 25th Anniv./88 IROC Z28 Vert
Engine: 305 TBI w/Tpi Air / 305 TPI
Transmission: 700r4/700r4
Axle/Gears: Posi
Re: parking brake "coupler"
Post some pics of the problem area
Old Jul 25, 2008 | 12:45 AM
keeslinger31's Avatar
Car: Camaro RS
Engine: obd2 350 lt1
like where the lever connects to the rod?
Old Jul 25, 2008 | 09:02 AM
gorbilax's Avatar
Car: 1992 Firebird
Engine: 3.1L LH0
there are cables going in from three directions. If you follow the brake cables from each rear brake, they reach a point where they are joined to a single cable that travels to the front of the car by a metal bracket. This bracket is what's damaged. If I remember correctly they come together just in front of the rear axle. When I looked under there to try and find it, there was something blocking my view, which I think was the exhaust, but now I can't remember. (It was late last night... sorry). Once I get back over to the shop, I'll jack it up and get pictures if I can.
Old Jul 25, 2008 | 12:25 PM
Car: Camaro RS
Doesnt it kindof have a plastic roller and if thats broken you are in danger of rubbing the cable till its broken that may be why it failed
1992rs/ss
Jan 31, 2025 05:10 PM
Frozer!!!
Jan 19, 2024 04:55 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
LittleFranks
Sep 17, 2015 12:22 PM
