How to remove parking brake mechanism on PBR's
Old Aug 1, 2008 | 05:28 PM
Saber's Avatar
Car: 91 camaro RS, 87 T/A
Engine: 350 TBI, 305 TPI
Axle/Gears: 4th Gen 3.42/BW 3.45
So im rebuilding my caliper and im trying to get the parking brake thing off the back of the caliper so it makes it easier to work. Do you even have to remove it to rebuild a caliper? and if so how to you get at that weird screw that holds it on. It is covered by a plastic nipple but it has a weird head, i took the nut off but the bolt wont budge.
Old Aug 1, 2008 | 07:35 PM
ebmiller88's Avatar
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
Re: How to remove parking brake mechanism on PBR's
You don't need to remove the spring and brake lever but it helps in getting the caliper completely clean. Review the following link and see if it helps.
https://www.thirdgen.org/forums/brak...t=brake+spring
Ed
1992rs/ss
Jan 31, 2025 05:10 PM
Vintageracer
Jan 10, 2020 05:33 PM
ZMWojnar
Brakes
May 12, 2019 10:43 PM
Eric-86sc
Apr 3, 2016 03:52 PM
3rdgenparts
Aug 8, 2015 07:09 PM
