moser 9" brake options
Car: 88 gta
Engine: 350 turbo
Transmission: t5
Axle/Gears: 4.56
ive gotten some what frustrated on my options i cant find a difinitive post, it seems like i can use an upgrade kit form flynbye or at least thats the impresion im getting from various posts. my rear is with the big ford bearing. so can i only use explorer brakes? (if so what year)??? if not should i get different housing ends??
i just ordered it so it might not be too late to make a change.
advice ?? anyone??
advice ?? anyone??
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: moser 9" brake options
if you still have time to change the order, get it setup for 4th gen, 98-02, 12" rear discs. A good and not too expensive setup.
Car: 86 Trans Am
i guess i should have asked where you getting the rear. Moser will make it with anynumber of housing ends. You need a housing end for 98-02 rear discs, the ones you mentioned are not the same.
Car: 88 gta
Engine: 350 turbo
Transmission: t5
Axle/Gears: 4.56
i ordered straight from moser, im going by what was listed in there ordering info sheet with various ends. those mentioned were the only ones under GM
Car: 86 Trans Am
call them and ask for them , i have them. I checked their site and i remember seeing a different list of housing ends that had schematics and dimensions and listed all the possible options.
I ordered my rear from exotic performance.
Car: 88 gta
Engine: 350 turbo
Transmission: t5
Axle/Gears: 4.56
the 4 gen brakes do clear the GTA honeycomb ( as i call them) 16 inch?
and ill callem first thing tomorrow about those ends
Car: 86 Trans Am
i know the fronts are an issue. I dont know about the rear
red90IROCls1
Aug 25, 2015 06:56 AM
