Rear pads
Old Aug 8, 2008 | 03:18 PM
Fire"Dutch"Bird's Avatar
Car: '88 Firebird Formula 350
Engine: 350 (5.7 TPI)
Transmission: auto 700R4
Axle/Gears: BW 9-bolt L.S.
Rear pads
Are the brake pads on a '88 Formula WS6 front and rear the same?
And do I need any hardware, like springs or bolts etc. to fit the pads, or can I reuse what's on it now?
Thanks!
Old Aug 9, 2008 | 06:38 AM
kcb37's Avatar
Re: Rear pads
I am going to assume it's 4 wheel disc.
You won't have any springs.
If your calipers are good you can just compress the piston, throw on pads and bolt the calipers back on.
I would recommend having the rotors turned.
I would also recommend taking the "slide bolts" (bolts that mount the caliper) and cleaning them and putting some grease on them.
Then can seize and hold the caliper so your brakes don't release.
Old Aug 9, 2008 | 02:26 PM
Re: Rear pads
Thanks.
I've read somewhere, the calipers have to be compressed by turning a screw or bolt..??
And what do you mean by turning the rotors?
And yes, I have rear discs.....!!
Vintageracer
Jan 10, 2020 05:33 PM
Eric-86sc
Apr 3, 2016 03:52 PM
Vintageracer
Aug 11, 2015 08:13 PM
GEmrsn
Interior Parts Wanted
Aug 8, 2015 03:15 PM
