Do these brakes look right?
Old Aug 12, 2008 | 11:49 PM
racing geek's Avatar
Car: 1987 IROC-Z
Engine: 383 with Edelbrock ProFlow EFI
Transmission: TH350
Axle/Gears: 12 bolt 3.73 Eaton posi
I just got this rear end from the junkyard today. It is a 9 bolt with a posi 3.4X gear ratio and disk brakes. However, when I got home, I noticed the calipers looked funny. The calipers are on opposite sides of the rear. The passenger side caliper is ahead of the rear and the drivers side caliper is behind the rear. This isn't normal is it? How can I fix this? Should I just go back to the junkyard and exchange it for a different rear?
Thanks,
Mike
Old Aug 13, 2008 | 01:11 AM
Al Hasse's Avatar
Car: 1992 RS / 1989 RS
Engine: 3.1L MFI / Vortec 383 TBI
Transmission: T5 / LS-T56
Axle/Gears: 3.42 open / 3.73 Eaton posi
Re: Do these brakes look right?
I have the same on a 10 bolt rear with cast iron calipers. From what I've heard, it was one of GM's ways to make tooling easier by making only one casting. Both of your calipers have the same part number
Old Aug 13, 2008 | 06:54 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Normal. As an FYI, the PBR's are both on the rear.
JamesC
Old Aug 13, 2008 | 11:55 AM
Car: 1987 IROC-Z
Transmission: TH350
Wouldn't that cause more torsional twisting than if the brakes were on the same side of the rear?
How easy is it to switch back so it looks right... just need a new backing plate and caliper? Will PBR calipers bolt right up to this rotor?
Old Aug 13, 2008 | 12:10 PM
JamesC's Avatar
No. The rotor is 10.5, the PBR rotor 11.7. The swap is PBR, however, is straightforward:
https://www.thirdgen.org/forums/faq-...iscs-89-a.html
JamesC
Old Aug 14, 2008 | 08:24 PM
Saber's Avatar
Car: 91 camaro RS, 87 T/A
Engine: 350 TBI, 305 TPI
Axle/Gears: 4th Gen 3.42/BW 3.45
Thats how my 3.45 9 bolt looks, the brakes are on opposite sides. I actually didnt notice it till i swapped in my 4th gen rear. Id get rid of those brakes though, they suck. And nice find on the 3.45 9 bolt, there pretty hard to find.
BADNBLK
Convertibles
Sep 21, 2015 07:56 PM
dbrochard
Sep 19, 2015 08:13 PM
Necron
Brakes
Sep 14, 2015 12:45 PM
Buickstaged
Brakes
Sep 4, 2015 07:53 AM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:50 PM
