PBR/LT1 rear caliper on LS1 rear disc?
Old Sep 26, 2008 | 11:43 AM
Jeffrey Fontaine's Avatar
Car: 1992 Z/28
Axle/Gears: 2.73's I think
I searched for quite a while, and couldn't find anything that would answer this question. I would prefer to have the larger diameter and thickness rotor of the LS1, but would prefer the smaller piston of the LT1 (to keep bias close w/ C5 fronts). I'm assuming this won't work because I think the LS1 is a drum in hat e-brake setup, so not sure how the LT1 would actuate that. Never hurts to ask...
Thanks,
Jeff
Old Sep 26, 2008 | 08:25 PM
krisb410's Avatar
Car: 91 RS Camaro, 75 L82 Corvette
Engine: LO3, 383 Stroker
Transmission: 700R4, TH400
Axle/Gears: 4th gen 3.23 posi/LS1 discs, stock
Re: PBR/LT1 rear caliper on LS1 rear disc?
I'm pretty sure won't work, with no modifacations. Hopefully someone who knows for sure will chime in. I put LS1 brakes on a LT1 rear, had to pull the axles and swap backing plates. The LS1 e brakes are a drum inside the rotor, totally different than the LT1 brake.
Old Sep 26, 2008 | 11:30 PM
ebmiller88's Avatar
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
Won't work. The LT1 caliper isn't wide enough to hold the LS1 rotor thickness (.81" LT1 vs. 1.0" LS1)
Ed
Old Sep 29, 2008 | 08:49 AM
Car: 1992 Z/28
OK, thanks guys. I wasn't sure if there was enough space, but I trust Ed since he lives and breathes F-body brakes
Orr89RocZ
Apr 25, 2016 08:28 AM
Scorched1984
Wheels and Tires
66
Apr 16, 2016 06:56 PM
sailtexas186548
Jan 19, 2016 12:21 PM
MustangEater82
Brakes
Aug 11, 2015 07:52 AM
