drum to disk questions
Old Sep 27, 2008 | 10:34 AM
iroc3o5's Avatar
my current set up in my 86 camaro is the stock 2.73 open differential with drum brakes.
i am slowly blowing the rear end out of this thing. since i redid the motor with almost twice the power.
i have found locally a disk brake posi rear end, and the seller is willing to throw in the proportioning valve as well, so i can switch to disk brakes.
do i also need the disk brake master cylinder, or can i just switch to the disk proportioning valve with my drum master cylinder?
thanks in advance!
Old Sep 29, 2008 | 09:24 PM
iroc3o5's Avatar
Re: drum to disk questions
Old Sep 30, 2008 | 06:58 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Yes. You can use either master, though I'd use the disc/disc. Grap the disc proportioning valve. By the way what year is the donor car?
JamesC
SpaniardV6
Brakes
19
Sep 7, 2015 03:04 AM
Warlocksirix
Sep 3, 2015 12:26 PM
Ducati900ss
Sep 2, 2015 09:05 AM
Bstrang6
Brakes
Aug 24, 2015 06:45 AM
redmaroz
Aug 16, 2015 11:40 PM
